1972 servicar
Bronx238st
Post Thu Feb 16, 2012 12:58 am
1972 servicar
is their a kick start kit for the electric start transmission thanksv
Post Thu Feb 16, 2012 8:43 am
Re: 1972 servicar
No....you need to replace the electric start case with a kick start case. You also need several of the kick start components the electric start type does not incorporate, both internal and external components. Extensive machining can be done to convert an electric start case to a kick start but it is much easier and less expense to just find a good kick start one, rather than to go through the machining process and parts change over.. However.....you can convert a kick start to an electric start fairly easily.
Bronx238st
Post Sat Feb 18, 2012 1:18 am
Re: 1972 servicar
thanks very much
Return to Servi-Cars
