Is K cylinder junk ???
Tim 435
Post Thu Jun 19, 2008 6:33 pm
Purchased this one off e-bay awhile back, figure i been had as the seller failed to photo or mention the very thin wall of the exhaust port :x , so whats your opinions, useable or a doorstop ? thanks, Tim
Jerry Wieland
Post Thu Jun 19, 2008 9:15 pm
Re: Is K cylinder junk ???
If that is the only thing wrong with the cylinder I would fix and run it or possibly even run it as is. I grew up on a farm and there was very little that could not get fixed with a little ingenuity.
Jerry
44dwarf
Post Fri Jun 20, 2008 3:06 pm
Measure the ID and compare to the other cyl if the offset one is big, machine round it and sleave it drill and pin it on the thicker side in two spots. I would stay away from any welding, except a a good spray welder but ther few and far between thewres alot of hacks out there with spray weld set ups.
44
Tim 435
Post Mon Jun 23, 2008 5:25 pm
Hey Jerry, maybe the local Amish blacksmith can do something with it :idea: , if not, 44d 's idea should at least give it more support, thanks, Tim
milwaukee belle
Post Fri Jun 27, 2008 12:57 am
i don't have any knowlege in Ks..
but i remember have dees the SAME original "factory-tooling-ERROR" on panhead heads ...
i really think you can run this cylinder without problems !!!
if the ex.port breacks ( one day ) here will be the time to repair it .
for the moment : this cylinder i "good for service" .
suicideshovel65
Post Fri Jun 27, 2008 11:21 am
I agree with MB, however check to see if any exhaust pipe angles are going to be changed or similar due to the off-centre whatever-it-is that's going on there, as it may affect bracketry etc depending on severity! Perhaps go easy on tightening the clamp, and shim/sleeve the spigot if required?
The rest of it looks pretty good IMO - worth hanging on to at least until you find your "welder/machinist extraordinaire" guy.
