Twin carb KR set up
Mike
thefrenchowl wrote:Nice... I did have nearly the same set-up on the KHK some years back...
A good idea with square Spanish Amals on a H-D is to install the heavier brass slides... I know of and I have had quite a few stuck slides on the fully opened position... Kill button at the ready!!! I've also seen extentions fitted on the top to fit longer/stronger springs...
Now, Mike, don't take this personnaly/litteraly, I'm only after more info, but the H-D race shop couldn't make the domes work at the time, what are you doing today that you think will make them work?
thefrenchowl wrote:Hi Mike,
Thanks for the update.
As you might know, racers could be cagey at the time!!! H-D did advertise a bit the domes, the pistons and special heads were available in the parts books, but as far as I can acertain, they only try to use the domes at Daytona 69 where most of the factory guys reverted to flat during the extra week before the delayed race...
Can't remember where I read it, but the dome was tried in the fall of 68 on the dyno with the factory special one cylinder KR and it was reported as a success, but as usual, big difference between dyno read-outs and actual performance on the tracks!!! Another 69 problem was that they somehow had less time than in the fall of 67 and they did try too many things at once, megaphones, domes...
Lawwill might be right about Mikunis vs Tillotsons... Tillotsons are all or nothing, not strong in the mid-range so there might have been an advantage to switch to other set-ups on flat tracks where torque did matter... I did talk a few times with Mert, but that was some time ago, during his racing bicycles years, he did not seem too keen to peer in the past, classical stance of a still very competitive man!!! He's now back in the motorcycle fold so might be more willing, hope you'll manage to talk with him again. That old KR of his was also raced in 70 when the Waffle Iron was broken, there's some photos of Mert on it with #1 plate in actual races, same for his protégé, Mark.
Keep us informed as you progress... Is that engine of yours for racing or just to play around? I also saw the Garage Company, Japanese owner, has got a dome 69 engine restored last year, do you know anything about that one?
All the best from Patrick
