SWINGARM LENGHT ?
milwaukee belle
Post Sat Feb 16, 2008 7:32 am
SWINGARM LENGHT ?
Can you please gimme these lenghts ?
i need to know !
dlm32
Post Sat Feb 16, 2008 7:39 am
Re: SWINGARM LENGHT ?
Belle,
These are rough measurements:
10.75" swingarm pivot center to center line of lower shock mount.
16.5" swingarm pivot center to the center of the rear axle channel.
Hope that helps!
DLM32
Post Sat Feb 16, 2008 8:19 am
Dlm, your dimms must be from point to point.
Dimms squared from pivot are A: 10" 6/10, 270mm, and B: 16"1/10, 410mm when axle is near the front of the slot. These are for early swing arms, 52K to 66XLH/69XLCH. Later Sportster ones have a bend in the tubes and are 1" longuer.
Some variants in the early ones: K/KH/XL/XLH, fitted with long chain guard, machined/threaded cast tab near front right.
On XLCH, that tab is not machined/threaded, the smaller guard is fixed to inside threaded boss that is part of rear casting. Still later, round hole tab welded on rear right leg tube for stop light switch anchorage.
milwaukee belle
Post Sat Feb 16, 2008 11:06 am
" A. equals 270 Mms , B. equals 410 Mms "
that's enough for me !
thanks a lot !!! :D :D :D :D :D
suicideshovel65
Post Sat Feb 16, 2008 5:40 pm
Was there another shorter version somewhere along the way?
