Mon Jul 07, 2008 7:25 pm by suicideshovel65
Hi Nick,
What carb will you run? You can choose the tank to be vented or non-vented (earlier) to suit. They're all pretty much the same shape, same brackets - the XLR is dual bung. The early sportster tanks have a LHS petcock which works well with the LHS carb.
The tank in your pic looks right - see how the rear mounts protrude a little rather than sitting under the tank (later model)? The vented tanks will have a small tube at the front left on the underside. You should be able to get a nice OEM tank for around $80 or less depending on condition and source.
I will be switching the front end over to a shorter set, and running them parkerized (or somewhat rusty...) with boots.
No light for now, but if I don't get a racing number plate fabbed up with a flush-mounted PIAA spotlight set into it, then I will possibly run a Bates bracket and light or stock light flipped upsidedown if that will work. No visor on this one, and no dash. Speedo if/when fitted will be side mount or bar mount mini. I'd prefer a tacho!
Colour I have been fretting over for some time - I'm partial to (faded, stained and browning) silver on vintage machines, but then the groovy 60s paint job on the XLR tank has grown on me so much I might go all psychadelic or scallops on it yet.
I'm envisaging this bike was a built mid-60s I guess, now with the 12V electrics and -60 wheels, etc...
Then again I have the hummer decals for the 55-56 (I like those 50s decals a la the race bikes), and it would be neat to use them on the CH tank. The rear fender with sparto tail lamp is a dark green and nicely beat-up, so it might be nice to match the tank and have the gold of the decals on that dark green. (go the green and gold)
Can anyone tell me if the hummer decals (OEM NOS) have a red coloured section in the middle? I can't see through the backing paper. If so I may need to trim them and then finish with lacquer...
