Board index Flathead Power-Technical Questions, Answers, and Suggestions K-Models HELP
HELP
Post Sun Feb 03, 2008 12:01 am
HELLO IM LOOKING FOR ASET OF OIL TANK MOUNTING GROMMETS FOR A 56 KHK ALSO IMLOOOKING FOR A SET OF SHOCK COVERS THE PLASTIC ONES FOR THE SAME IM RESTORING A 56 KHK AND THATS BASICALLY ALL I NEED FOR ASSEMBLY OF A COMPLETELY ORIGNAL PART RESTO, THNKS FOR ANY HELP :D
Post Sun Feb 03, 2008 3:30 am
Hi, Dinuns1,
Welcome here!!!
The rear shocks plastic covers were only used in 52/53, after that these covers are in stainless steel. The plastic ones are the same material as the kidney shaped paniers, made out of plastic Royalite, started as a flat sheet, rolled and riveted on the back. The company is still out there, it might be possible to find some flat sheets still...
As for your grommets, they can be made out of rubber sheet. The most important is that you have the 3 special "stepped" screws that prevent overtightening of the grommets.
