55KHK Trap door question (transmission access plate)
Yep,
KH trap door have 6 bolts and 2 conical dowels, never seen one of these trap doors on their own for sale anywhere... Seen a few sets of cases on eBay with them so they are out there...
By the way, in 1957, when the new 4 bolts trap door was introduced on the Sportster, H-D had all the spare KH cases in the part dept remachined for the 4 bolt type, stamped with a "D" around the boss for the engine number, so it's possible to have your cases remachined to fit a Sportster trap door...
We put a newer style Trans from Tiawan Ted in my 55KH. We used the cone shaped dowls and modified the new door to fit them. I will call my machinist and ask him what he did. He said it was simple.
I have the old door, but am saving it for a back up.
The V-Twin trans will not slip into first gear without first rocking it up into second gear. More quallity parts from Tiawan. Other wise the trans works well. The new trap door does not have the mounting boss on the door fot the center screw to hold on the primary cover. I had a friend make me a bracket to mount with the bottom bolt that holds on the chain tensioner. It is kind of a pain to line up the first time, but then I marked it by drawing a line along the edge of the chain tentioner onto the bracket with a sharpy. I allined the threaded hole in the bracket by mounting the cover and then shining a flashlight through the hole to see how close the hole was to the spot the light made on the bracket.
It can be done.
Barry
It can be done.
Barry
Yep, Barry, but you can find early Sportster trap doors with the cover center screw boss:
Sporster 1957 to 1965, with taped boss, -54 part number (i.e same as KH but bored straight for the 2 dowels):
Sportster 1966 to ?, with boss, untaped, -54A part number:
Sportster 1977 and later trap door, for left shifter, boss deleted, -76 part number:
All the best for this end of year festivities...
Hi Greybeard52,
My 1954 KHK is 54 KHK 254*, also matching bellys, right code and NO trap door. Considering the low output, about 1000 KH per year or less, this is well past mid-year production...
The parts books don't mention the transition point on that one, just the change from -52A to -54A, unlike changed rake parts on forks from 54 KH 2250.
The trap door is actually not listed, it was sold as a set with the left case. The conical dowels were available, number 24578-54.
Talking about this change of rake, Greybeard, are your forks original and if so, haven't you ever wondered about some of their aspects? PM me if yes, I want to confirm some strange original parts on mine...
All the best from Patrick
Hey Barry,On the sporty trans if first gear is hard that is a symptom of first gear on the countershaft being shimmed too tight against the case side and not being able to freewheel easily.Try a thinner 1st cs shim or see if the face of the gear is rubbing and needs to be releived a bit.Not the original subject,just trying to be helpful.
Since no one has mentioned it,I thought I would bring it up!. I'ld like to see someone start a registry for K's,KH's,KR's as I know of 2 1954 KH's that are doorless,as I've stated before;the early cases can be machined for the trans door=no problem!!. If interested contact me at sportsspecialties1@yahoo.com. BREWSKI
Hi, BREWSKI
I did certainly have a good look over the years at my 54 KHK trapless cases, there's no way one could machine that to retrofit a trap door, not enough meat in the vertical casting...
One can see on trap door case left castings where the factory added meat on the vertical wall from the outside. That's also a quick check to ensure trap or no trap without taking the primary out when buying a 54 KH...
