KH piston clearance
• Page 1 of 1
Does anyone have a factory documentation or service letter that specifies the piston to wall clearance for a 1956 KH?
Hi Hans,
As you know I just put my KH back together again…. I have found over the years, yes even with bad breather timing, that it will run without seizing from .oo2 to .006 with aftermarket cast pistons. This is the key though, as after market pistons I have been told have a bigger expansion rate than the stock pistons. I just set mine up between .003 and .004 as we had to re-hone, and it was on the tight side the first time on this bore. Since I don’t know how you run her, I would suggest that .003 would be a safe place to start. Stock pistons from the factory were recommended at .001 to .002 .
Over .006 and it is likely time for a new bore. Most on the forum would recommend that you have the top and bottom of the cylinders torque plated when you have them bored to get the best possible set up, ending up with a round bore. Making the plates takes time, but may be well worth it.
It is still raining on my days off, so my bike sits in the garage waiting for a test ride. Pouring today, but it is Seattle so what do you expect? Of course when I am working, it is beautiful!
Best Regards,
Barry55KH
Best Regards,
Barry55KH
yes kr and xlrs need more clearance. as they r run harder and more heat. been duing it for years. not all pistons need same clearance cast is diffrent than forged. with kr xlr xr 750 when they r cold should not rev much till motor warms up. if u use v twin listen to fellow who had experance. cant beat that. if possible check with piston mfg. they will give u cleanance.to bad kieth black {silverlite} dont make them the r xlint pistons. i have some new kr pistons. but have used v twin they seem to work well. best to listen to experance and piston mfg. specs. best to u.
• Page 1 of 1
