KH or KHK
hotrods1
Post Mon Nov 07, 2005 5:53 pm
KH or KHK
Does anybody know the difference between KH cylinders / heads and KHK cylinders / heads? And how to identify them? I have a '56 KHK with pretty screwed up cylinders and am considering putting some other KH's I have on it. But if the cylinders that came off it are KHK and worth the effort I might repair them. The parts book lists different part numbers but I've compared and I can't see much difference. Any thoughts?
Larry
BREWSKI
Post Mon Nov 07, 2005 6:59 pm
KHKcylinders have polished ports,and KR size valves. I used to own 3 KHK complete engines,still have a spare set of KHK cylinders. brewski
xlr
Post Mon Nov 07, 2005 7:25 pm
big diffrence is kh cly. is longer than k
BREWSKI
Post Mon Nov 07, 2005 7:44 pm
That is true,the obvious difference is in the base flange. BREWSKI
hotrods1
Post Mon Nov 07, 2005 9:40 pm
khk and kh are both the long stroke motors. so cylinder length would be the same correct?
RUB-BOY
Post Tue Nov 08, 2005 4:00 am
I think only difference between KH/KHK cylinders is polished ports and combustion chamber.RUB-BOY
Post Tue Nov 08, 2005 11:00 am
As I recall from my 55 KHK and what the old timers told me when I owned her. Polishing was really the only differences between the two. The KHK was polished everywhere flow restriction could be a factor, from intake, to cumbustion chambers, to exhaust. I almost positive on this. "Almost" :wink: Pa
xlr
Post Tue Nov 08, 2005 11:12 am
yes kh and khk cyl. same. polished on khk not kh. heads same u can use kr heads they help a lot. when u install heads try to bring to kr specs
hotrods1
Post Tue Nov 08, 2005 8:37 pm
Thanks for the info,
I thought there wasn't much difference. I'll use my better KH cylinders.
Larry
greybeard52
Post Wed Nov 09, 2005 9:02 am
KH ports can use a LOT of cleaning up. Mine had a lot of really rough spots; cleaning up and polishing only took a couple of hours. Was worth it. G 8)
