QUALITY WL, WR, K, KH & STROKER PISTONS
MOLDTHREAD
Post Tue Nov 06, 2012 11:40 am
Hi Guys,
I am trying to see how much demand there would be for top quality racing pistons for the 45's and if it would be worth doing.
They would be Forged pistons made in the USA by one of the top manufacturers of Power Sport pistons.
They would be similar in construction to what is used in the XR 750 racers.
They would have Teflon coated skirts, supplied complete with standard pin, locks, and rings.
Rings 1mm top, 1.2mm second, 2.8mm 3 piece oil .
Available in flat and domed top, standard and +.040 to start with.
WL's would need pop up heads.
Stroker pistons would also be a possibilty.
They would be an "off the shelf" item with a price in the $150 each range.
Bruce Argetsinger
AHRMA Dirt Track # 67J
http://www.enfieldracing.com
Bruce Argetsinger
mike100m
Post Wed Nov 21, 2012 11:05 pm
Re: QUALITY WL, WR, K, KH & STROKER PISTONS
Copnt me in Bruce. Definately interested.
Mike
scaryguy
Post Thu Nov 29, 2012 4:33 pm
Yes! Yes! Yes! You can count me in! I want to use T&O stroker flywheels for a wl/k project. I have early, (short) K model cylinders and stroker pistons that allow me the required amount of pop-up would certainly make my world a happier place! I would be interested in at least three sets of pistons for various 45 projects on the go. Thank you!
BREWSKI
Post Fri Nov 30, 2012 12:41 pm
What comression ratio would be available in the domed piston version? I'm interested in a set for my KR/WL, 0.020" OVER, 4 1/2" stroke. TIA
MOLDTHREAD
Post Fri Nov 30, 2012 5:29 pm
The C/R would be dependent on the head you used, dome pistons would require the 69R head.
It doesn't make sense to use them with another head.
I probably will be making these but it is a ways off.
Bruce Argetsinger
