54KHK with 57 Sportster top
Kurt
Post Mon Aug 04, 2008 9:46 am
Anyone ever see this combo?
Had a customer come in with pix this morning. Good looking bike, but are there any special issues.....and/or......has this already been talked about?
He wants to put it back to stock, but I said it may be better left alone........comments?
He's going to send me pix to post.
Kurt
Barry55KH
Post Mon Aug 04, 2008 10:34 am
Re: 54KHK with 57 Sportster top
Hi Kurt,
I would check to see if the tapet blocks are K model or Sportster? I have seen Sportsters stamped with K model numbers when a title was not available. The angles just don't line up to put a Sportster top on a K model bottom. It is eazier to buy a Sportster or a K model engine.
Best Regards,
Barry55KH
Post Thu Aug 07, 2008 7:04 am
Choices:
1. bad numbers as described
2. K-style cams - adds a new and bad angle to the pushrod at both ends, since the tappet block (either K or Sportster) is angled in the right case and should not be for the XL box
3. Sportster cams - the tappets will do #2. above, and also make edge contact between the lobe and roller edge
4. actually welding or plugging the tappet block holes and re-drilling at the proper XL angles - I've not only never seen this done, the question instantly caused the conversation to cease when posed to the owner/builder/planner of such a project
