Re: K Piston Rings
Hi Ritchie,
Don't have any WL pistons to compare with my stash of KH pistons, BUT, rather than buy straight away a good new pair of WL to fit in your KH/KR project, just invest in one dead WL piston and check for yourself with a 1/2 crankcase + crank + piston. You'll know the depth of your heads from measuring them, substract .5 to 1mm (20 to 40 thou) for the squish band, see how far more the WL piston pops up, (it's bound to be more than KH std as 8mm = 1/2 stroke diff WL to KH as I'd rather think the diff between WL and KH piston height is more like 4mm) , the result will be the height of the plates you'll need under your cyls.
Patrick.
Patrick.
