flat R/H to shovel L/H?
flatheadrider
Post Wed May 03, 2006 3:54 pm
Anybody with any knowledge mating flatty right side cases to other year left side cases? I am thinking about running an altenator on my flat.
fabercycle
Post Wed May 03, 2006 4:40 pm
They make several different alternators that bolt on to the generator boss, for all early HDs.
Seems like the grief youd go through trying to miss-match parts that were never meant to be, would be a tremendous waste of your time.........not to mention the time someone will spend someday trying to fix the "jerry-rig" job someday 20 years from now.
But they are your parts....so feel free to do what you want.
Kurt
Post Thu May 04, 2006 2:53 am
Yes, it has been done and as a matter of fact I was looking at it this morning. A "LOT" of work and welding, but it does look cool and will be a centerpiece wherever it goes. He's even going to run hydraulic tappets in it. In his situation, he's a mechanic and a welder, so the project was a spare time one. If you can't do the work yourself, it'll cost a ton of money to have someone do it based on what I saw when he was doing it and how long it took. If I get pix, I'll have someone post them.
Kurt
Post Thu May 04, 2006 6:45 am
Kurt
Post Thu May 04, 2006 6:49 am
Panic, I'll have a really neat new item available real soon....expensive....but tests show that about 150% oil increase....from a stock pump. I'll send you pix when I get them.
Kurt
flatheadrider
Post Thu May 04, 2006 6:55 am
Thanks Panic, that was the kind of info I was looking for. I have known OHVs could swap around but didn't know what differances were between OHV and SV (besides motor mount). Sidebar queastion, how do you access the "company news" forum, I can't seem to find my way there anymore?
flatheadrider
Post Thu May 04, 2006 7:01 am
Thanks Panic
Thanks Panic, that was the kind of info I was looking for. I have known OHVs could swap around but didn't know what differances were between OHV and SV (besides motor mount). Sidebar queastion, how do you access the "company news" forum, I can't seem to find my way there anymore? WTF!!!!??????????? Site just told me I CAN'T POST ANYTHING NEW SO SOON AFTER LAST POST (last night! - 12 hours ago) How are we supposed to communicate freely on an open forum. I saw something about the new "moderator" and deletion of the "edit" option or something. What is going on?
dalaymond
Post Tue Aug 08, 2006 10:00 am
This is a little off topic, but I have an old "Choppers" magazine, with a picture of an engine with a BTFH bottom end and a shovelhead top end (and I don't mean a 45 bottom end with a sportster top end). Whether it actually ran or not, I have no idea. But, it is still kinda cool looking.
john k. endrizzi
Post Tue Aug 08, 2006 10:32 am
Dal,
Why don't you scann the image and post it here? It sounds like a very real example of a MORPHIDITE !
JKE
dalaymond
Post Tue Aug 08, 2006 8:43 pm
I will be glad to scan it and email it to someone who can post it. 'Cause, I don't know how. :roll:
Post Tue Aug 08, 2006 8:46 pm
I'll put it up for you. Email it direct to me. Make sure you put something in the subject line refering to it or I may accidently delete it. Pa
dalaymond
Post Tue Aug 08, 2006 8:49 pm
Thanks, Pa!
I'll do it as soon as I get to work in the morning.
Post Wed Aug 09, 2006 9:57 am
Dal's pic......
Post Wed Aug 09, 2006 12:45 pm
dalaymond wrote:This is a little off topic, but I have an old "Choppers" magazine, with a picture of an engine with a BTFH bottom end and a shovelhead top end (and I don't mean a 45 bottom end with a sportster top end). Whether it actually ran or not, I have no idea. But, it is still kinda cool looking.
I have seen several of these hermaphrodites. All of them were built by "Williams Motors". Mike Williams started doing them in his Van Nuys, CA shop back in the 70's. William's Motors/Iron Eagle is now located in Canyon Country, CA. Joe at William's may build one for you, but don't hold your breath waiting for it.
JIm
Post Wed Aug 09, 2006 8:28 pm
There are a couple of those that I know about and probably more that I don't running around New England and they we not built in C.A. but by crazy N.E Yankees. One is in NH the other is in CT.
J
dalaymond
Post Thu Aug 10, 2006 7:45 am
That's cool to know that they do run.
Do they run about as well as a typical 74" gen case shovel?
100incscoot
Post Thu Aug 17, 2006 8:54 am
i bet they run a bit better
just the str8 pushrod to rocker rather then being angled would gain you some power
its amazing how much energy is lost by angling the valve train
indianut
Post Thu Aug 17, 2006 1:37 pm
Post Thu Aug 17, 2006 4:45 pm
Now why didn't HD do that ? I like it a lot !! Pa
little stanley
Post Sun Jan 14, 2007 9:27 pm
I agree with Pa on the angled pushrod subject. If you look at a Knuckle you'll notice that the intake rockers are "inset" from the exhaust and all pushrods are straighter than the following Pan, Shovel and Evo motors that have all of the head holes "in line". They had it right with the Knuckle so why did the screw up so badly?
I'm also of the opinion that the knuckle oil system (I never owned one, guess somebody out there would like to squirt me) was superior to the Pan in that not only were the feed lines external of the motor but the return system thru the pushrod tubes kept the oil away from the hot cylinders. Seems like the Pan setup with its heating of the rocker oil both coming and going is totally wrong, it'd be just fine if I were one of Santa's Elves and lived at the N. Pole but I live in Texas where its hot.
Been thinking of looking at a set of '63-'65 heads and heliarcing some aluminum bosses to an older set of heads, plug and drill holes as needed to at least fix/update the feed side via the cam cover. Any body ever try this?
-little stan
