Thu Apr 12, 2012 9:16 pm by antiquespeed&machine
Scaryguy- My transmission is still a three speed. I only bought the case. I found two minor and one major problems as I built the transmission. The lid screws were 12-24 instead of the 10-24 they were originally (no big deal). There was one of the lid screws that was incorrectly located. I welded it up and re-drilled/tapped it (OK, mistakes happen). The last one was the distance between the shift cam shaft and the shift arm gear. They were .050" too close together!!!! And to top it all off, installing the shift gear is one of the last steps, so it all had to come apart again to fix it.
I did not buy the four speed for several reasons. One, too expensive. Two, untested. Three, The HP the bike puts out will most likely ruin the trans at some point, I figured I would ruin the cheaper, easier to get parts. I do not believe fourth gear was any higher a ratio then third was in the three speed. Its only benefit was smaller "steps" between gears. That would benefit the stock 45", but with close to four times the HP in my engine, I don't need it.
Jib- Yes, grease from the zerks is how the rockers are lubricated.
