FASTEST Harley EVER ....
milwaukee belle
Post Thu Dec 09, 2010 2:20 pm
on a 1941 rolling chassis ( see the fork )
so sad ?
or génius ???
Post Thu Dec 09, 2010 2:32 pm
Re: FASTEST Harley EVER ....
WOW !! Got to be some power in that for sure ! The frame tube beneath the fuel tank looks bowed from the engine weight. Pa
Neil74
Post Thu Dec 09, 2010 6:00 pm
Is that an early shot of one of E J Potter's hot rods?
LarryP
Post Fri Dec 10, 2010 7:28 am
Widowmaker
john HD
Post Fri Dec 10, 2010 11:38 pm
looks to be about a 16 inch rear sprocket to boot!
yikes!
john
Post Sat Dec 11, 2010 1:01 am
How does he cool it ? No water pump and the water jacket ports are linked together.
Post Sat Dec 11, 2010 9:03 am
Pa wrote:WOW !! Got to be some power in that for sure ! The frame tube beneath the fuel tank looks bowed from the engine weight. Pa
Pa!
I would guess that was one of the "field conversion" frames mentioned in literature, where the spine was massaged with a maul to increase the rake.
Post Sat Dec 11, 2010 10:02 am
Probably a 265? Canister oil filter engine? Gotta admire guys who just jumped in and "did it", no matter whether it should have been done or not.... Yeah John, quite the sprocket, maybe he also removed the wheel and used it on the farm as a buzz saw! :lol:
epinut
Post Sat Dec 11, 2010 10:12 am
Frankenstein wrote:Probably a 265? Canister oil filter engine? Gotta admire guys who just jumped in and "did it", no matter whether it should have been done or not.... Yeah John, quite the sprocket, maybe he also removed the wheel and used it on the farm as a buzz saw! :lol:
Nope, side mounts says -58 & up...
fhsmith1
Post Sat Dec 11, 2010 1:29 pm
Heads look like later that that. This looks like ones that the alternator and other brackets bolted directly to the head. Must be later than 1967. Valve covers look like older. No PVC system. Looks like a 3 two's intake with the middle carberator hole blocked off.
F
Post Sat Dec 11, 2010 3:52 pm
Potter again, same sort of "scaling", but with Allison airplane engine...
I believe Potter's V8 bike already had telescopic forks by the time he was doing the drag strips in 65, that photo above is obviously anterior and could be termed 1st draft??
STROKER
Post Sun Dec 12, 2010 12:47 pm
I've read Potter's book,he used a stock Knuckle head frame,later versions of the bike were hilborn injected. STROKER
Post Mon Dec 13, 2010 12:33 am
Pa wrote:How does he cool it ? No water pump and the water jacket ports are linked together.
How hot can it get in 10 seconds?
Post Mon Dec 13, 2010 6:25 am
Not hot to the point of complete failure if he starts it and goes immeadiately. :lol:
Malte
Post Mon Dec 13, 2010 3:43 pm
Seems he`s concerned `bout weight too, looks like the late light WR rear fender.
STROKER
Post Mon Dec 13, 2010 6:53 pm
Notice the starter, it was direct drive,it was started on a rear stand and dropped to the ground for a running start. The heads are for a '68 and later SBC,the cannister oil filter is pre'67,the valve covers are pre-'63. STROKER
Post Mon Dec 13, 2010 7:43 pm
I would think push starting it would be almost quite impossible unless Big Bertha [ one of the butt sisters] was onboard with him. LOL
Neil74
Post Mon Dec 13, 2010 8:23 pm
Once dropped to the ground, he would burn the rear tire almost the length of the track and still run 140-150mph. I wonder how many times he went down in his career.
MarkBranst
Post Mon Dec 20, 2010 12:26 pm
Here's a good link to recent discussions about the Michigan Madman!
http://www.jockeyjournal.com/forum/show ... hp?t=51018
Mark
panacea
Post Wed Dec 22, 2010 2:44 pm
Looks like a "curio" to me, is that an exhaust system or just upper motor mounts? Marv Jorgenson would be proud!...Mike
