Mon Aug 10, 2009 3:14 am by greg1
All i can say is i'm in the middle of building a twin to your bike and didn't even know about your build.I have a wish list for my solo project and one off the biggest things for me is it MUST be black,frame,springer,handlebars,fender,etc.
I too have khk cylinders,i found a stock bore set,and KH heads,i'm running KH cams as a friend of a friend sold me a choice matching set from the same bike for $150.00.I figure i'll just change to Bruce's KHK cam lobes if the KH cams don't satisfy me.I'll be running a set of 4 5/8" wheels and sportster rods.I'm even using shouldered aluminum wheels like you're running.I plan to stick with drum brakes,mostly for the vintage look.
This isn't just a pipe dream i'm having, i already have a 1941-46 solo frame,stock springer front end,aluminum 18" sportster shouldered wheel assemblies,KHK cylinders,KH heads and cams,a mint set of 1951 W cases with cam cover,and a few brake items,etc.I won't be able to get her done by this riding season but i'm putting every bit of my energy and funds in having it done next summer,or fall at the latest.I also plan on running Bruce's tappet guides,i've corresponded with him several times and he's very helpful.Who's lifters and what brand did you decide to run?I'm curious to the valve springs you run as well.It'll be good info as i want to start out with springs that won't bind at KHK cam lift.I had planned on running those cams but $750.00 was the cheapest used set i found .I have the matched set of KH cams now in mint shape for the $150.00,so even after spending $500 on new KHK lobes from Bruce i'll have a basically new set of cams for $650.00.
Well sorry to rattle but now you've motivated me to spend a couple hours on the bike today.
And as to the eye candy you look to be very fortunate in the lady department as well,no disrespect intended......
