Board index Flathead Power-Technical Questions, Answers, and Suggestions Sporties Strange Sportster Cases
Post Mon Apr 09, 2007 12:20 pm
JIm
First year with numbers on the right side.
Post Mon Apr 09, 2007 2:19 pm
Hi Ironpimp,
Yep, rare one: one year only cases, 1970
up to 69: serial on left case,
71 and later, serial in the middle of the inlet tappet bores.
In 1970, they had it between the front cylinder tappet bores because they still had the vertical timer...
And 4A is an XLCH, blank plate should cover the electric start hump on top of the clutch.
Post Tue Apr 10, 2007 10:41 am
JIm
What thefrenchowl said. He beat me to it and had more info than I did. I saw a number of them many years ago that had the number boss machined off and someone stamped supposed 69 numbers in them.
Heard other rumors that pertained to them but I figure they were just rumors that could never be verified.
Jim
Post Tue Apr 10, 2007 9:35 pm
1970 Shovelheads were the same way.
Post Thu Jul 19, 2007 5:03 pm
I believe they are. I'll check my sons 77 and see for certain. Pa
Post Fri Jul 20, 2007 12:29 am
All 1970 frames had numbers on them. I have see very early ones without a raised pad. Simply an area decked off and numbers stamped there.
Post Fri Jul 20, 2007 6:35 pm
I have a good friend who had his 69 Shovel taken away at Daytona because of a raised number boss on his frame neck. There were no numbers ever stamped on the boss.
Post Sat Jul 21, 2007 2:54 pm
When we went to the impound yard they were going to torch the neck off making the frame un-useable. We pulled the tanks off and insisted they take pictures of the top motormount, frame neck and after leaning the bike over to both sides the belly numbers. These were sent to I believe Pete Seeger? in Millwaukee, at Harley archives. They told them to give it back it was stone stock. two weeks later my friend received a letter from Harley stating his machine slipped out of the factory with the 70 frame but all of the numbers were correct. hell of a feeling watching that torch be lit, sure glad we fought it!
Return to Sporties
