Board index Flathead Power-Technical Questions, Answers, and Suggestions Sporties piston ring gap
piston ring gap
Post Sat Jul 22, 2006 2:18 am
Hey guys. Does anyone know the piston ring gaps for an ironhead sportster. The manual I have gives specs of .008" top and .008" second ring and oil control .015". These are specs for an XR 1000. (This is for my Magnum conversion...900cc.)
Post Sat Jul 22, 2006 11:55 am
Vince the XL 1000 and the XR 1000 are the same bore and stroke,in fact you can use XL pistons in the XR for higher compression. You're in the ballpark on the ring end gaps. BREWSKI
Post Sat Jul 22, 2006 5:39 pm
Thanks for the confirmation Brewski. I have another source that states .015" minimum on the top ring. I'll stick with your confirmation and the factory's specs.
~Vince
Return to Sporties
