Board index Flathead Power-Technical Questions, Answers, and Suggestions Sporties 1000cc S&S Crank/Flywheels/Rods into 1957 Cases
Hello, Newbie here. Can I install 1000cc S&S Crank/Flywheels/Rods into stock 1957 Cases?
Yes You can provided you're not building a stroker,the S&S catalogs used to explain clearly the codes on their flywheels. All 1957 to 1976 bottom end parts interchange with the exception of pistons,1971 and later camsets are different also. The rods and flywheels interchange as well as the bearings.
The "Tech Info" link at the top of this page may answer your questions. Hold your cursor over the link and select what you are searching for.
Thank You!
Return to Sporties
