Tue Aug 11, 2009 5:04 pm by Lee W
Have you checked the accel pump setting? It's adjustable. Turn it down till it doesn't do anything then open it up again just enough to get a decent squirt. Have you tried it with the air cleaner on? You probably never will get it so that it will take throttle if you snap it open too quickly, on the other hand you should be able to roll it on at a reasonable rate. Have you asked your local engine builder what he thinks?
