Board index Flathead Power-Technical Questions, Answers, and Suggestions Sporties XR 750 CAMS
XR 750 CAMS
Post Tue Jul 01, 2008 7:16 am
Hi All,
I'm looking for some help.
I just got a set of XR 750 cams that I'm going to measure and start reproducing. I would like any information on these cams that anyone can give me as to aprox. date, who they may have been made for, what racers may have used them, what type of tracks they were used on, and where they fit into the XR development history.
These were made by CR Axtel, with lobes welded to the gear clusters, all lobes are stamped 055, one of the gear clusters is stamped on the lobe side "79" which I am sure is factory stamp and is preceeded by letter? "I" or "J", hard to tell because weld starts to overlap.
Thanks for any help,
Bruce
PEEK Seals & HOT cams for flatheads
http://www.enfieldracing.com
Bruce Argetsinger
AHRMA Dirt Track # 67J
Post Sat Jul 05, 2008 8:29 am
If those cams are from an Iron Head XR 750 then they are from a model of which very few were ever produced.
Post Sat Jul 05, 2008 10:58 am
Hi, Bruce,
Iron XR used the "A" grind, probably a "PB" XLR grind adapted for smaller stroke.
Early alloy XR are "E" grind from memory, -72R set, listed in parts books as having the following opening/closing: Intake 33-54, Exhaust 67-18.
New grind in 74, "no letter stated" but -74R set, Intake 33-54, Exhaust 64-24.
The "J" grind is -79R set, Intake 43-57 1/2, Exhaust 67 1/2-29
No mention of lifts anywhere...
Hope this helps,
Return to Sporties
