Board index Flathead Power-Technical Questions, Answers, and Suggestions Twin Cams loose shifter lever on FLHR tranny
Post Tue Sep 11, 2007 8:32 pm
Anybody had experience changing out the shifter lever on the left side of the tranny without removing the primary? I'm thinkin' pull the top off the tranny,along with the shift drum assembly,then pull the splined shaft out thru the top,replace the lever and push the shaft back out where it was. I got the circlip off the splined shaft(fun) . I thought she might push in far enough to get the lever off, no luck. I dont want to be out ridin' up Beartooth and have that loose lever fail on me. Mike
Post Sun Sep 16, 2007 8:54 am
I couldn't get the shift pawl out thru the top without pulling the trap door so I had to pull the inner primary. mike
Return to Twin Cams
