pulled out cylinder stud/head bolt
DocTonyNYUL46
Post Tue Aug 21, 2012 3:51 pm
Need Help!!! started to torque down heads on a 1987 evo and pulled one of the cylinder stud/head bolt out of the case/block! Any suggestions for a fix. I was going to use 2-helicoils. One bike mechanic said it woul not work, two others said that they use helicoils all the time and work fine. Any feed back will be appreciated.
Thanks,
Tony
amklyde
Post Wed Aug 22, 2012 6:27 am
Re: pulled out cylinder stud/head bolt
A helicoil will work fine if the instalation is done correctly. You will need to come up with a drill and tap guide to keep the insert perpendicular to the base surface. You will of coarse need to make sure no chips are allowed to fall into the crankcase. Clean the hole with carb spray and apply a little green loctite or sleeve retainer to the outside of the helicoil. You will need a small needlnose plyers to hold and break the install tang at the bottom of the coil. Studs are designed to have an interference fit, so give the loctite time to set up before threading the stud in, making sure the insert does not thread in. Its a pain of a job, but if you take your time and do it right it will work fine.
Return to Evo's Thru 99
