rattling cover on compensator
Post Mon May 31, 2010 7:48 am
hi guys my mate has a 86 fxr and the primary compensator cover spins , when the engine is running it sounds like it has a loose tappet, any ideas, i havent had any experiance of these drives and am in hospital.
Post Mon May 31, 2010 10:49 am
Re: rattling cover on compensator
There may be a bit lost in translation here.
I don't know of a cover for the compensator. A common problem is the rotor for the alternator which is under the compensator will get loose and spin. When this happens to only fix is to remove it and install a new one. This because as it spins the center hole becomes oblong. I am surprised it is still charging.
Post Mon May 31, 2010 3:04 pm
ok, thanks chris , i'll let him know, its difficult because i cant see the bike, and that was his description to me, so it could still end up being the loose nut behind the handlebars yet.
regards jib
Return to Evo's Thru 99
