Weld cracked at rear "Y" pipe on 1991 FLT
Need more late model help. Had exhaust leak at "Y" exhaust pipe off rear cylinder on my 1991 FLT with 68,000 miles and stock factory exhaust with Samson slip on mufflers. Took rear pipe off and found factory weld had come completely seperated at the "Y". The weld is intact, but the small part of Y pipe has completely seperated from the weld. All tail pipe mounts/brackets were in place and tight. Is this common. Does this mean the front motor rubber mount is worn out? I am going to have pipe welded and put back on, but would like to cure the problem before it happens again. Thanks, Buster
