80 & 81 heads
X-WLCH
Post Sat Sep 21, 2013 11:24 am
80 & 81 heads
Did HD leave the lower valve spring collars out of these heads? I have a set that are 1.375 from the head without collar to the upper collar. Or did they run a special low lower collar with less spring space ?
amklyde
Post Mon Sep 23, 2013 8:58 am
Re: 80 & 81 heads
They have lowers that sit directly on the head, no support from the guide. 80-81 motors always required spring spacing work when you installed any higher lift cam. Spring space with upper only at .375 seems extra tight, aftermarket valve a little short or thick at face?
Return to Shovels
