82 Shovel missfiring
My 82 FXE has started backfiring an missing sporadically, I suspect the gel battery is giving up after 2 yrs of use. While trouble shooting I checked the ohms of my coil,oem # 31609-80, according to the shop manual primary should be 3.3 to 3.7 ohms and secondary should be 16,500 to 19,500 ohms. I am getting 4.5 primary and 23,900 secondary, do these high readings show coil as being bad? I have allways found readings to be low or no readings at all on other bad units, I am ordering a new coil but wondering if readings show bad?
