big bore pan
• Page 1 of 1
I'm going to build a new motor with 3 5/8 cylinders and stock stroke of 3 31/32 will this be a good combo?
Re: big bore pan
bikerwilly wrote:I'm going to build a new motor with 3 5/8 cylinders and stock stroke of 3 31/32 will this be a good combo?
Why not just build the Square Motor? 4" x 4".
Re: big bore pan
The big-bore, short-stroke combination has been invented every 10 years as a new idea.
Since re-balancing is required anyway, it offers no advantage over the same displacement (81.9") achieved through stroke increase (4-3/8" is about the same at 81.2"), which is more effective.
More stroke will eventually limit engine life and maximum RPM, but not near where you are now.
You might get a better squish band - but only if you actually machine the parts yourself, they won't come like that.
The flywheels also offer you a choice of at least 3 weights.
What is it you're trying to do?
Re: big bore pan
I have flywheels out of a 56 74in was going to use them with std 3 5/8 bore cases . just though i'd use the wheels i have as it in good shapr and has rods on them.
Re: big bore pan
I have no experience with such a combination in a Pan, but a big-bore stock-stroke Chubble turned out to be a delightful torque machine, able to pull a fully-loaded sidecar faster than anyone should, for several round trips to Sturgis from Illinois.
The owner insisted upon an overhaul at ~25,000 miles, as he had never gotten that out of a motor before.
I found nothing to fix, leading me to conclude that it is a very durable formula.
Note: It was originally an 80", but that is still a 'short stroke' to a lot of us.
Re: big bore pan
Certainly preferable to stock bore, needs smaller compression dome for the same ratio, no down-side except that it's slightly more knock-prone than a std. bore if the quench is too large, but has better quench than stock if the quench is properly limited.
You're going to rebalance it, yes?
Re: big bore pan
Someone mentioned 4 inch bore. Were would you find heads to accomodate this?
Dick
Dick
• Page 1 of 1
