Pan head castings
Post Mon Dec 17, 2007 9:48 am
Pan head castings
I'm finding more variants than Palmer shows, including 2 different 1956.
What I have so far (appreciate any clear pics!!):
http://victorylibrary.com/tech/panhead-c.htm
Any more I should list?
Jerry Wieland
Post Mon Dec 17, 2007 9:11 pm
Re: Pan head castings
Panic I know of 2 original late 1954's with the 1955 type D ring. Casting is the same as 1950 to 54. These bikes both have the straight leg frame. Jerry
Post Tue Dec 18, 2007 12:11 pm
Thanks.
Palmer also says that the FLH (ported) head is labor only, same casting - but I find more casting numbers in this series: 16704 and 16706-55, in which the ports appear to be "as machined" (obvious step below the valve seats) - should these be the FL heads?
