Board index Flathead Power-Technical Questions, Answers, and Suggestions Pans Bendix Using OE Internal Throttle Controls
Post Sat Sep 01, 2007 11:32 am
Here's a Bendix on Ryders' 71 XLCH. "Push" spiral was used with OE stiff-wire, but if you put the cable entering from the bottom instead of the top, you would use a "pull" spiral.
He used these Kwik-set fastener pieces and made a throttle cable block.
