Board index Flathead Power-Technical Questions, Answers, and Suggestions Pans Panhead rocker shafts and blocks
Post Sat Nov 25, 2006 12:44 pm
Hi everyone. Does any of you Panhead guys know what the end play is? or should be ,on a new rocker shaft and block for a Panhead.
And,does anyone know of any possible way to fix excessive end-play on the rocker shafts? Thanks.
Larry
Post Sun Nov 26, 2006 12:30 am
0,004"-0,012" I braze the blocks up a little on the side.
Stéph
Post Sun Nov 26, 2006 9:56 am
Is it just the top bronze block that you braze? Or the cast bottom block as well. Thanks.
Larry
Post Sun Nov 26, 2006 5:04 pm
Why not shim it ? Pa
Post Sun Nov 26, 2006 9:04 pm
Pa, it sure would be nice if you could shim it. The rocker and pushrod arm are permanently attached to rocker shaft,so there is no way to slide shim onto shaft,(like a shovelhead)
Post Sun Nov 26, 2006 11:52 pm
I braze up both to have an even sidepressure.
Stéph
Post Mon Nov 27, 2006 4:10 am
My goof. :oops: Thanks.. Pa
