Board index Flathead Power-Technical Questions, Answers, and Suggestions Pans 53 FL Pinion
53 FL Pinion
Post Fri Oct 18, 2013 8:08 am
Just bought a set of S&S generator cases (pre-65 style) . I know my flywheels from my 53 motor will not fit and will need a sproket shaft for a timken main bearing. However, does anyone know if I could use my 53 pinion shaft and gear as long as I make sure the bushing in the cam cover is compatible?
Any help would be appreciated. Thanks
Post Fri Oct 25, 2013 5:04 pm
The diameter of your pinion shaft at the bearing surface is nominally 1". The '58 and later case race is used with a 1.250 diameter pinion shaft. Short answer: you need a later shaft and associated gears also.
