Muffler Hangers
Tim 435
Post Thu Nov 01, 2012 6:16 pm
Muffler Hangers
Installing dual exhaust on my 65 Pan, according to the parts book there are 2 part numbers for the hangers, one right one left and both use a spacer ? Found some in my stash , when mounted they either bend inward or out ward depending how you mount them, not sure if they're correct or the correct way they mount, to make things more intresting I found one that when mounted is straight but bends up or down ,, any ideas ? thanks, Tim
George Greer
Post Fri Nov 02, 2012 11:20 pm
Re: Muffler Hangers
I was asking that question too for my mishmash 58FL project that I am collecting parts for and sending to the US.
Answer I got:
When looking forward from the rear wheel, the muffler supports:
Should point, Down and inward.
George
Tim 435
Post Sat Nov 03, 2012 9:07 am
Re: Muffler Hangers
Got that George, turning in while mounting on the outside of the frame, appears the pre 65 called for spacers , still baffled with the 2 part numbers , thanks for the reply, Tim
