Tappet block?
George Greer
Post Sat Sep 08, 2012 9:47 pm
Tappet block?
Need to ask about fitment of shovel tappet blocks on a panhead engine.
The tappet blocks have these numbers cast/impinted on them
18601-73 FRONT
18611-73 REAR
Will they fit and work properly on a 58FL engine?
The ones I have got plenty of wrinkle black paint on them, and it is hard as a brick..........so, once I get the paint off of them, I can see that markings are on them.
George Greer
PS, I am planning on using Andrews J cam, and solid lifters.
Thanks
amklyde
Post Sun Sep 09, 2012 9:14 am
Re: Tappet block?
They will work fine George.
George Greer
Post Mon Sep 10, 2012 1:14 am
Re: Tappet block?
Kyle...
Thank you.
George
PS, on the blocks that came off of the engine,
Rear one has busted up ears, and it is off a shovel... front one, is original pan.
Thanks again for the confirm!
panacea
Post Mon May 20, 2013 10:50 pm
Re: Tappet block?
Hi George, did you ever check the clearance on those lifter blocks? They looked great to my untrained eyes but I never checked the fit...Mike
