Oil in timer/circuit breaker
fogfrank
Post Fri Nov 19, 2010 6:22 pm
Just finished a COMPLETE rebuild of my 69' shovel. And, this is a new one on me, I have oil in the base of my timer/circuit breaker. Anyone have an idea on this. fogfrank
woody
Post Fri Nov 19, 2010 7:08 pm
Re: Oil in timer/circuit breaker
If I remember correctly, there should be a reverse spiral cut on the top of the distributor shaft that keeps oil from coming up into the top. Your problem could be caused by loose bushings, excessive shaft end play, or too much internal pressure in the engine. I'm sure there are other things also, but these are the ones I know about.
