Board index Flathead Power-Technical Questions, Answers, and Suggestions Pans Solid state regulator question
Post Sat Oct 25, 2008 7:55 pm
I just picked up a 1950 Panhead that has a solid state regulator on it. All the wiring from the regulator to the dash is missing. Wires are dangiling here and there. The regulator is still connected to the generator, although I don't know if this is correct or not. Does anybody recgonize this regulator? Which wires go from it to where on the ignition switch? I have never messed with one of these before. :oops:
Thanks in advance.
Post Sat Oct 25, 2008 9:03 pm
chris
not knowing the manufacture i would say in general it would be:
black=battery
red=armature
green=field
john
Post Wed Oct 29, 2008 6:53 pm
If you look at the back of the unit you might find a manufacturer, etc., and then do a google for the spec sheet or instructions.
