front wheel stand for 1944 U
• Page 1 of 2 • 1, 2
I need a front wheel stand for my 1944 u model.I believe the correct stand for this year had a bracket or clamp on the the rear rod that bolted to the front fender to hold the stand up.Does any body know what the part # of that bracket or clamp is?
Re: front wheel stand for 1944 U
I'm pretty certain the bracket is #3006-36. Pa
That part # is for the the bracket on the rear of the front fender that bolts to the clamp on the front wheel stand to hold the stand up.I need the clamp that is on the front wheel stand.Thanks for your assistance.
The fender part I noted bolts to the stand and fender. I'll post a parts drawiin. Pa
PA,that front stand you posted,is not the correct one for a 44u.Kurt has a correct one on his site,but it does not have the clamp on it that I am looking for.
Part # 3001-36N looks nothing like the above picture. round stock between side pieces.
don
don
Chalk another error up in the parts books.
The "U" shaped angle iron was replaced by the stamped stand in 1943. The catch is the same part used on civilian bikes through at least 1954.
I have the correct catch that bolts to the fender.I need the clamp that is on the fender stand,so that I can put a bolt through the catch and clamp to hold the fender up.Thanks for the picture Chris.
Never seen a part number for that clamp.
New stands would always include the clamp to replace the earlier style stand.
Hope this helps:
Hope this helps:
Thanks my Good Friend !! Another typo in the factory parts books ! I did not know about the 1941 front stand. I thought only wlc 45" had them. Pa
Rene,That is the clamp I need.That is a good picture.
Oui.......I can see it. Pa
Fran-6
Take a look at this. It's a copy of a Type 1 BT front stand we have.
https://flatland.oursafeserver.com/45partsdepot/catalogzoom.html?product_id=146573
Here's the Type 2:
https://flatland.oursafeserver.com/45partsdepot/catalogzoom.html?product_id=143414
Kurt
Here's the Type 2:
Kurt
Yes , Kurt !
i just visited your website about this subject on this morning and fond the two "NEW" stands ...
really good stuff !!!! i think you sure will sell a lot ! last year , i have searched and searched all around the earth to finally find an ol'one for my 42 ELC ....i will not tell you the horrible price
i paid for ....
why don't you add the tubular 1941 WL luggage carryer to your products ????
and also the 43 WLC blackout headlamp shroud ?
these are also parts you sure will sell a lot .
( anyway : your stuff is becoming best and best . really !!! )
Thanks Fran-6 for the Kudos........but I wasn't fishing for that.....it's always good to hear one though.
I was pointing out the part number compared to the one Pa has. His is the BT part number according to my books, but I can only find the late part number for the 45 WL/WLA stand as 49301-40
Is the 45 front stand early part number 3001-40?
This is one of those items that carried the same part number, but H-D changed the part.
As far as the luggage carrier, I thought someone already was producing a nice one.........no?
Kurt
Kurt
