Clutch pushrod for my 38UL #2446-38
HD_Handshifter
Post Thu Apr 17, 2008 12:03 am
Hi,
I'm searching for a original NOS 1938 clutch pushrod for my
Harley 38UL. Hope some one here can help me.
#2446-38 Clutch pushrod 1938
Thanks
HD_handshifter
Post Thu Apr 17, 2008 5:55 am
Re: Clutch pushrod for my 38UL #2446-38
http://www.nosparts.com/cgi-bin/dbsql/d ... ool_op=AND
Type the part number in the search block if the link doesn't take you directly to it. Pa
HD_Handshifter
Post Thu Apr 17, 2008 6:03 am
To Pa,
Well, I have tryed NOSParts, and I have also contacted them, but they don't have it. I'm searching for a NOS or
a used one if anyone here have one in stock.
Thanks for the help.
Best regards
HD_handshifter
Post Thu Apr 17, 2008 6:30 am
HD_Handshifter wrote:Hi,
Thanks
HD_handshifter
Why not use the new throwout bearing set up with the wafer bearing and fan? This fits the later Knuck and Pan pushrods and fits into your '38 kicker cover. V-Twin part number 18-3203 page 512 of 2008 catalogue.
HD_Handshifter
Post Thu Apr 17, 2008 6:48 am
Few important notes about using this push rod kit:
The finger that pushes against the bearing must be modified so it clears the retaining
clip on the end of the pushrod. You can not use the late style finger that already has
the clearance because it will not fit inside your cover (1936-1938 only).
Also, you have to check if the mainshaft has a bushing that supports the pushrod
(keeps the pushrod centered).
If it is not installed you can probably push it in (without disassembling the transmission).
Therefore I prefer the correct 2446-38 one.
Thanks
HD_handshifter
Post Thu Apr 17, 2008 8:15 am
HD_Handshifter wrote:Few important notes about using this push rod kit:
Thanks
HD_handshifter
Well, You are incorrect as the kit includes a new slotted finger that is made to work with the wafer bearing. I use these in all my restorations reguardless of year.
HD_Handshifter
Post Fri Apr 18, 2008 1:43 pm
Chris,
Okay, I'll try that. Many thanks for the great help.
Best Regards
HD_handshifter
