Board index Flathead Power-Technical Questions, Answers, and Suggestions Big Twin Flatties "hogged out" cylinder head bolt holes
Post Sat Apr 07, 2007 2:06 pm
hi all, got a set of BT aluminum heads that were drilled out to a big 1/2" size hole, as they were used on a cylinder set with 1/2" head bolts.
I want to use these heads on cylinders with 7/16 stock bolts, should i be concerned about the hole size difference, will the heads leak around the bolts??
building small sleeves will be hard, what about studs, any recommendations will be nice, as i am worried about head leaks around the bolt should i be??.
thanks.
thanks.
Measuring the hole in a new copper gasket with verniers gives .498 to .502 Since the hole is well "inside" the "embossed" sealing ridge, I think it`ll fly the way it is. JMO and I`m no expert!
OR, maybe a thin copper washer 7/16ths I.D. UNDER the stock steel washer for additional insurance.
