Board index Flathead Power-Technical Questions, Answers, and Suggestions Big Twin Flatties BT front brake sleeve
Post Mon Jul 10, 2006 11:08 am
The front brake sleeve on my BT springer has 2 shoulders cut into it. my understanding is that this is from a later hydo front end. It seems to work, but I would like to know if the seasonded wrenches out there think it would be better to change it out for the single shoulder (correct) type. Thanks, Randy
Post Wed Jul 12, 2006 8:47 pm
I would change it! Can't see how this (hydra sleeve)can be used and working on the springer. If I understood correctly...
Post Thu Jul 13, 2006 8:22 am
I believe Palmer says the two are identical except for the second shoulder.
Post Sat Jul 15, 2006 7:56 pm
Palmer says... OK. I have to take a look at them both. Maby they are identical and you then can use it. I always go for the correct type to be used on the diffrent forks.
Post Sat Jul 15, 2006 8:44 pm
I stand corrected. Palmer says they are similar. What I want to know is if anyone knows if having the Glide one installed is OK. thanks, Randy
