oil leak from hell
steph
Post Fri Jun 02, 2006 12:27 am
Panman what happens when you don't put a fluttervalve...oil will come running out off the breather of the cover.
But what you are discribing seems more like the returnpump that needs to be timed, imo.
Stéph
steph
Post Sat Jun 03, 2006 3:10 am
Fran-6 maybe at the frontvalvecover first...because the gasket is in less condition...
Maybe a sheared returnpump gear key...
But I don't see where the broken valvespring is going to get oil to pump out!
Stéph
Sideblåsern
Post Wed Jul 19, 2006 6:34 pm
First thing I would check is the condition of the gaskets and the leaking valve cover. That everything is as meant to be. Straight, and gaskets where they shold be and that they seat correctly. Often I have seen bent upper covers, wich will lead to leaking...
Users browsing this forum: MarkBranst and 1 guest
