UL/VL Hybrid
VFDBill
Post Sun Mar 12, 2006 11:38 am
UL/VL Hybrid
Hi everyone, this is my first post. I've been gathering parts for my next project which is to put a UL top end on a VL bottom and put it in a UL/FL type rigid chassis. For now Im just working on the engine. Has anyone done this before? I have five UL engines apart in my work shop right now plus the VL so I have lots of parts to compare. I can see that the UL cylinders need to be trimmed on the bottom to fit in the VL case and that the overall height of the UL case is taller than the VL. Is this going to cause a manifold fitting problem? Also using 74 pistons will reduce compression ratio. Any input would be appreciated, thanks... Bill
Post Sun Mar 12, 2006 1:06 pm
Haven't done it, seen it.
Yes, the spigot length is a bit long.
The manifold will be too long, the 1939 WLD manifold is about .110" narrower and may be a better fit.
74 pistons, meaning the UL barrels are 3-5/16"? Yes, that will reduce compression and also engine size.
Users browsing this forum: LarryP and 1 guest
