New guy looking for some help about UL's
justonefix
Post Thu Jan 05, 2006 4:30 pm
I'm going to look at some '48 UL cases this weekend andd was looking for a little advice anything to check seeing as this is the first motor I'll be working. Cracks/welds/repairs, and bad threads are the main things I'm thinking of. Numbers match, and they look real clean in the pics I was shown. Thanks for the help. I'm sure I'll be asking for more over this build.
44u
Post Thu Jan 05, 2006 6:14 pm
You can get around any bad thread problems. Usual places for cracks are motor mounts, cam bushings, and generator stand.
The matching numbers on the bottom of the cases is all fine and well, but make absolutely SURE the ones on the VIN pad are clean and unmolested. If you're not sure try to post a good, high quality pic here and someone may be able to tell for sure.
47knuck
Post Sat Jan 07, 2006 8:07 am
Welcome abord. You have found the place for help and support
Steve H
yp
Post Sat Jan 07, 2006 12:49 pm
Hello Justonefix.......I think on the 48`s the one belly number of the two should have the 4 hit twice(448-****)On a set i had a few years ago I thought this was suspicious,but apparently is original on 48`s.....
justonefix
Post Mon Jan 09, 2006 12:20 pm
Hey guys just wanted to thank you for the info, didn't get to go check em out yet but I'll let you know if all goes well.
Users browsing this forum: john HD and 1 guest
