Board index Flathead Power-Technical Questions, Answers, and Suggestions Big Twin Flatties Numbers Check
Numbers Check
Post Wed Sep 10, 2014 9:40 am
Guys,
I would appreciated some input on this mixed set of 42/40 cases. The 42 serial numbers look good to me, but is the pad original. If it has been altered, they did a pretty good job.
The only reason I ask is because they have been on the market for a long time, with no takers, at what I would consider a pretty reasonable price.
http://tinyurl.com/mnucbzm
Thanks in advance,
Mark
Post Fri Sep 12, 2014 9:28 am
Mis matched cases can cause you problems. It could be that the right case is from a stolen machine. You won't know unless a numbers savy LEO ruins your day.
Post Fri Sep 12, 2014 9:56 am
Mark, I’ve seen the left case on eBay before but at that stage the right-hand case with it wasn’t 1940; instead it was 1948 and its belly number was 448-1+++. And I sent you a PM.
Eric
