andrews cam set for UL
yp
Post Fri Jul 05, 2013 1:09 am
hello again,friend got a parts motor with some new parts....including a new set of andrews cams.....
when checked with originals the lobes on 2 looked different than the old oem set....
i am not a mechanic and know little about this stuff... but checking the parts catalogues there is only 1 stock andrews cam set ,
no variations..... any one have any experience with these cams....any ideas as to why they look different to oem.....
thank you for your time.....
helsingborg
Post Tue Jul 09, 2013 2:41 pm
Re: andrews cam set for UL
It's probably old inventory parts because you can only find Sifton replica nowadays(in fact v-twin mfg with sifton label). I heard Andrews used to sell UL cams with slightly hotter intake cam profiles long time ago. Depending on the lift and the duration you can use them in a stock motor. But super hot cam requires some engine work in order to work right. Try to search panic papers on this suject, google victory library tech papers and also kns kustom hotter UL cams.
Kurt
Post Tue Jul 09, 2013 5:42 pm
The UL cams are not V-Twin Mfg......they add the Sifton brand, but they are manufactured in Europe by the same manufacturer who makes the WL, WLDR and WR cams for over a decade now.
Kurt
amklyde
Post Wed Jul 10, 2013 7:37 am
I recently got the last set of stock replacement cams (for at least six months) for U models from Andrews. The ramps do appear to be more abrupt, but I think the lift is the same. The cams are very nice and run well together dry fit with new bushings. The only problem I had with them was the sizing on the inside journals, at .684 they were .002 under oem. I normal use the .6875 standard ream, but in the case I had to use an adjustable. Fortunately, the bushings were small enough on the ID to clean up at the proper clearance. Just something to consider if you are using a set of Andrews cams. If you try to use them as replacements without changing out the case bushings you will run very loose on the inside. Outside journals on 3+4 were correctly sized at .686.
helsingborg
Post Wed Jul 10, 2013 9:53 am
Kurt, sorry my mistake, 45parts depot have them fabricated in Europe and v-twin mfg resells them with sifton label, right? I have a set for my bike and they are perfect. regards
Kurt
Post Wed Jul 10, 2013 5:07 pm
No no, Samwel from Holland has them made and distributes them.
V-Twin does have some good things, just as long as it's from someone else.....lol
Kurt
sands
Post Mon Jul 29, 2013 9:55 am
I've seen the Andrews cam set now available from W&W cycles (item no.64-198) marked as 'new stuff'. The comments there are that they're 'mainly' the same as stock (mainly???) and the cam profile has been computer optimized. I hope to get some more accurate information regarding lift and timing - or has anybody already checked this?
sands
Post Mon Jul 29, 2013 10:29 am
Got some information from W&W cycles: shaft diameter for case bushing is 0.6840" only (same as amklyde noted :roll: ) - can't understand why they made the shaft smaller than OEM...
cover side: cam 1: 0.7815", 2: 1.1235", 3&4: 0.6860"; valve lift 0.375"; duration 212deg @0.053 tappet lift.
Post Mon Jul 29, 2013 8:29 pm
It is doubtful they will scrap all the cam sets so I guess the solution to the journals is to make you own bushings.
MOLDTHREAD
Post Tue Jul 30, 2013 6:16 am
As a manufacturer of racing parts for vintage motorcycles, I find it very hard to understand how a company can knowingly put on the market parts that they know do not fit correctly.
What kind of business ethics is that.
Unfortuanteluy that is what we have to accept from some of the major manufacturers of repop parts.
Bruce Argetsinger
AHRMA Dirt Track # 67J
www.enfieldracing.com
Post Tue Jul 30, 2013 6:37 am
I alerted a major USA vintage hardware manufacturer when their latest offerings were drastically undersized.
The reply was: "We gotta sell these first".
Post Fri Aug 02, 2013 11:37 pm
Cotten wrote:I alerted a major USA vintage hardware manufacturer when their latest offerings were drastically undersized.
Would that be venturis?
Post Sat Aug 03, 2013 5:01 am
Yes, Chris,
And these days they fit.
(Beware of steel offerings on ebay from another source, as they are tragic.)
