1936 92 ci VL
TURK
Post Sun Mar 31, 2013 6:34 am
1936 92 ci VL
What do you think?
amklyde
Post Sun Mar 31, 2013 7:45 am
Re: 1936 92 ci VL
I like it. I can imagine the difficulties in finding the right length rods and pistons to work in VL cases at that stroke. Any special oiling and breather modifications to make it work?
TURK
Post Sun Mar 31, 2013 8:17 am
Re: 1936 92 ci VL
You think the stroke was tough, how about this? -- Turk
TURK
Post Sun Mar 31, 2013 8:21 am
Re: 1936 92 ci VL
A nother view
fhsmith1
Post Sun Mar 31, 2013 6:34 pm
Re: 1936 92 ci VL
I LOVE IT!
1948u
Post Mon Apr 01, 2013 10:46 am
Re: 1936 92 ci VL
I am truly blown away! That is quite a piece of engineering. You must have a few hours into this old girl. The question I would like to know is how fast does it go?, and how quickly does it get there?
wilko
Post Mon Apr 01, 2013 5:24 pm
Re: 1936 92 ci VL
What a stupid useless unrideable waste of time! Just get over your obsession with choppers. Everything has been done before!
TURK
Post Mon Apr 01, 2013 9:57 pm
Re: 1936 92 ci VL
You don't like 150 mph flatheads,what a boring person you must be.
amklyde
Post Tue Apr 02, 2013 5:50 am
Re: 1936 92 ci VL
When I saw the pic with the blower, my first thought was you were a little "touched" in the noggin Turk. If you tell me you have been over the ton on this machine, I'm sure nuts, or wacko, would be a better description. I would love to hear the beast run, ride it, and/or ride alongside for a while. Do you put any serious miles on it? Choppers are fun.
TURK
Post Tue Apr 02, 2013 8:27 am
Re: 1936 92 ci VL
The ton ? 3rd gear without the blower.
Post Tue Apr 02, 2013 10:50 am
Re: 1936 92 ci VL
at the risk of being a party pooper, where's the charging system?
TURK
Post Tue Apr 02, 2013 12:12 pm
Re: 1936 92 ci VL
Brit , Total loss system, it's a race bike attempt at having the worlds fastest VL. 92 ci stroker, big valves, beehive valve springs, kr type conture porting and relieving, Cut down and reworked Eaton m- 90 supercharger, S&S super g carb converted to methanol, T&O flywheels late model Carrillo style rods and crankpin, reworked oil system, UL style pistons, speedpro rings, tapered moly wristpins. Cams will be Shovelhead lobes pressed on to VL shafts 286 duration .450 lift Sifton experimental from my old shovel racer.
1948u
Post Tue Apr 02, 2013 5:46 pm
Re: 1936 92 ci VL
You'll have to keep us appraised at your attempt at having the world's fastest VL. Does anybody know what the current record is? And for that matter does anybody know what the current UL speed record is?
Post Tue Apr 02, 2013 9:15 pm
Re: 1936 92 ci VL
wilko wrote:What a stupid useless unrideable waste of time! Just get over your obsession with choppers. Everything has been done before!
BACK OFF !!!!!!!!!
TURK
Post Tue Apr 02, 2013 11:00 pm
Re: 1936 92 ci VL
1948: I think the currant ul record is around 148 or so fuel unblown by Paul Feibus (sp) David Pilgram has the ul turbo record at about the same speed, I think he runs alcohol. Dale Walksler runs a VL at Maxon I'll call dale tomorrow and see how fast he's went. Back in 1935 or 36 The California highway patrol tested about 40 VL's at the same time at 100 or over to pass purchase qualification. Steve Slocum in England has some CHP replicas for sale guaranteed to go 100 mph stone stock . Mine should run about 120 without the blower 150 with---time will tell---cant brag till you dunnit.
wilko
Post Wed Apr 03, 2013 5:04 am
Re: 1936 92 ci VL
Gee mister moderator, I'm intimidated! I have an opinion,so do the others. Grow up!
Post Wed Apr 03, 2013 5:31 am
Re: 1936 92 ci VL
I believe Paul's UL record is currently 150 and change. He's also working on a blown unit, turbo in his case.
Way to go Turk, beautiful piece of work.
Post Wed Apr 03, 2013 6:34 am
Re: 1936 92 ci VL
wilko wrote:Gee mister moderator, I'm intimidated! I have an opinion,so do the others. Grow up!
Since you are not intimidated, you may consider what your opinions are before they spue from your mouth to your finger tips. You comment was purely insulting. It was far from an opinion. If you do not like the bike, it is easy enough to just state that, rather than attack the builder with insults. As for you comment about me, I refuse to grow up. I happen to be the bigger kid on this playground and if you piss me off again, you will have to find yourself another playground to play on.
Post Wed Apr 03, 2013 7:06 am
Re: 1936 92 ci VL
.........coming back onto Planet Earth for a while, I'm also a bit puzzled by the bike. There seems to have been a great deal of time, effort and money spent on an engine which is then mounted in a frame with radical steering angle mods, hugely extended springers, forward footrests and all the "chopper" style. To be honest, it doesn't LOOK like a serious race-bike at all.
I'd be curious to know more about the whole Maxton/records thing, because there seems to be quite a story here?
37ULH
Post Wed Apr 03, 2013 12:01 pm
Re: 1936 92 ci VL
A new location in Ohio has been secured and run beginning last year in Wilmington, Ohio, a couple of hours from the house. DHL had a hub there and moved out and they have use of one of their old runways. Great location.
The Maxton course has been abandoned due to condition of the runway although the run logs and records should still be available through their site:
www.ecta-lsr.com
The VL is a project of a friend of Dale's and i believe he made his best run at the 1.5 mile track in Maine, breaking the ton. He's using a UL/H top end with aluminum heads with reworked chambers, inlets, and a later 4 speed trans.
I hope to put my WLA/K down the track again this year. I sold a speed twin to my previous rider so we can go head to head in the same class when he's ready.
Users browsing this forum: Yahoo [Bot] and 3 guests
