Board index Flathead Power-Technical Questions, Answers, and Suggestions Big Twin Flatties 1936 92 ci VL
1936 92 ci VL
Post Wed Apr 03, 2013 7:30 pm
The bike started as a chopper, then I got this bright idea . The forks will be changed and the fork angle modified to 5" trail, foot pegs moved to rear , handle bars lowered. I am familiar with what is needed for land speed racing, after 25 years of drag racing in 2011 I built a shovel head and took it to Bonneville in 2012 we took it to the Texas mile , best yet has been 161 running way rich. Thank you for your concerns , all comments and criticism's are appreciated they help to make a better machine.-----Turk--born 1936 same as the VL P.S. Yes, I built it , I ride it
Post Wed Apr 03, 2013 7:58 pm
....that's what was puzzling me. Does this engine have a racing history, then? Or is it a completely new project?
Post Wed Apr 03, 2013 10:26 pm
The motor I acquired in 1972 with a bunch of VL stuff , I didn't care much about it at the time so I put it on top of my mailbox for decoration it was on there For over 40 years until 2010 I decided to see if I could make it run. Didn't have any rods , flywheels , pistons,cams. So I used late rods T&O wheels and found or made the rest. The bike was completed in three months and ready to ride with a 92 cubic inch VL motor in 2010. It was four weeks ago that I discovered two blowers off of Buick v6's and got this bright idea and thought I would see if it would work. I read Panics paper on blowers and decided to try it. I was well into it and about finished and decided to discuss it with Jeff, he straightened me out on a few things, got me on the right track. It is up and running and pulls like Jack the bear. I'm used to riding race bikes and this thing is about half scary, but I'm getting kind of old.
Post Wed Apr 03, 2013 11:14 pm
PA: I thank you for your support , Please don't think I am offended by Mr Wilco's comments I realize the lord made many soles who are unkind and inconsiderate and must be tolerated. My best wishes to all--Turk
Post Thu Apr 04, 2013 1:17 am
where do you live, that you can have a VL motor on top of your mailbox for 40 years? It wouldn't last 40 minutes round my way before the pikeys had it away... come to that I wouldn't give much for its chances of running again after 40 years in MY front yard.
How long does it run an a total loss ignition system? My grasstrack bikes all have magnetos these days, or some sort of bump-and-go system because I got fed up with running out of sparks halfway through a meeting. I once had a BSA Bantam that ran off a battery ( dead charging coil ) and it used to run for about half an hour.
Post Thu Apr 04, 2013 9:08 am
No one deserves attacked unless provoked.
Post Sat Apr 06, 2013 5:34 pm
I was provoked. By the site of that unrideable thing.and to race it, even more dangerous! Put the motor in a decent frame and no more provocation.
Post Sat Apr 06, 2013 11:44 pm
That is a poor definition of provoked. With bikes it is as to each his own preference. Why not just say it is not your bag or cup of tea ? Why blast a person for their likes and dislikes ? You've been around here for quite a spell. You've been a fairly good member as well during that time. Must be something else bugging you because you don't come off the way you did towards a fellow member as you did this time around. I sure hope what is chawing at you subsides soon. Mellow out.
Post Mon Apr 08, 2013 3:31 pm
Blowers and turbos on a bike have never been my cup of tea, mostly because they just don't fit in anywhere...always sticking out someplace. However, forced air does make sense to me on an engine that does not breathe well normally. (flathead) I would think that a sidevavle would benifit most from forced air. I'd like to run a turbo on my '48 Dodge, as it would all hide under the hood. But, it just runs too well as is (dual B&B's) to mess with it. !!
Anyhow, to each their own, but I can appreciate it.
Post Tue Apr 09, 2013 8:48 am
Back in the 60s, I remember seeing some very tidy supercharger mounts on Triumph 650s, but I have no idea how they performed or better yet, how long they performed.
Mark
Post Tue Apr 09, 2013 9:30 am
supercharged 650cc Triumphs were used in grasstrack racing in the 60s, and of course drag racing http://www.theaccelerationarchive.co.uk ... ps_03.html
Post Tue Apr 09, 2013 3:21 pm
That was quite some reading.
I've often thought that a turbo might be ideal for a flathead, since most long stroke flatties produce lots of low end torque, then kind of runs out of steam as the RPM's increase. Seems like the turbo ( with it's lag) would start turning on about at that time, and would be a good combination. ?? That's why I've always thought that a small turbo off a four cylinder would work well on the flat six in my Dodge.
Having said that, I guess super charging adds power throughout the power band, so maybe it's better.
Post Tue Apr 09, 2013 7:22 pm
my guess would be that mechanical supercharging would be preferable for flatheads because of the "turbo lag" effect. I would guess that a turbo-charged flathead would do well enough as a drag bike but not on the road. isn't there a turbo-charged 45 that has appeared at Maxton? Maybe someone who has tried it, would comment?
Post Wed Apr 10, 2013 9:50 am
But don't you think that the flathead would be producing plenty of torque while the turbo was lagging, and then the turbo would kick in about the time the engine wasn't producing any increase in torque? I'm not sure where peak torque occurs with the Harley flathead, but with the Dodge it's very low in the RPM range, then you feel the engine kind of run out of "steam" as the RPM's build/increase. That's how it seems it would work to me...but I don't know. Just spit balling here!
And....are those aluminum heads that sat on top of that mailbox for 20 years??? !!!!
Post Wed Apr 10, 2013 7:30 pm
I'm thinking mainly of the effects on controllability and rideabikity. There were some very effective supercharged solos built in the late 1930s for road racing - they were remitted at the time - and I think that would be the direction to follow. BMW in articular had a very effective flat twin in that frm.
Post Thu Apr 11, 2013 9:31 am
Yes, I'm a bit of a BMW fan, and own one, and they did indeed have some success with super chargers...the flat-twin design/layout kind of lends itself to mounting a blower on the front of the engine a little better than a V-twin or even a vertical twin.
Post Fri Apr 12, 2013 10:20 pm
Google RS255 Kompressor, handsome thing and highlysuccessful
Post Sun Apr 14, 2013 7:54 am
Great looking bike ! I can appreciate all that went into that build,
I`d love to hear that motor run ,and see it going down the track.
Post Sun Apr 14, 2013 7:34 pm
I still want to know if a set of aluminum heads sat on that mail box, unmolested, for 20 years. !!!!!
Post Sun Apr 14, 2013 7:46 pm
They are iron, and corroded, but good inside, probably will get new alum ones .
PreviousNext
