Milling heads
woody
Post Mon Feb 20, 2012 9:55 pm
Milling heads
I spent the day today milling, grinding, CCing heads, and checking valve clearance. I have the heads down to 2CCs difference (114 and 116). The valve clearances are FI: .150; FE: .090; RI:.175; RE: .090. The head with the larger chamber has the lower Intake clearance. I am leaning toward leaving well enough alone and not messing with them any more.
Comments, ideas, opinions, please.
Lee W
Post Tue Feb 21, 2012 3:57 pm
Re: Milling heads
A couple of thought for you. On an 80 inch flathead the difference of 2cc would be about .09 of a point of compression. In other words, using raw head volume numbers uncorrected for piston deck height, gaskets and such, 116cc would give you 6.62:1 C.R. while 114 would give you 6.71:1 C.R. (That is NOT your actual C.R. - just an example)
Another thing I'll just throw out there: On late model Harleys, both Twin Cam and Evo, I have more than once measured a +/- of 1cc difference on new factory heads. So if you are within 2cc, then you are doing as well as the factory castings are today.
