Repro 13 FIN Cylinders 74" & 80"
Paul Friebus
Post Fri Oct 29, 2010 1:11 pm
Just to put my 2 cents out there. I am selling the 74" & 80" 13 fin repo cylinders too, in different configurations. I have thoroughly gone through these castings & have found the following :
- the base flanges are 50-60thou thinner than the stock base flange (i.e. 0.450 VS 0.500)
- the intake & the exhaust bores have some core-shifting & need porting to flow anywhere near original
- the exhaust external airflow also needs the flashings cleaned up
- overall the external appearance is a little rougher than Harley, but for the price, we are lucky to have them.
Future testing :
1. We will be testing to see how well they shape up when using 1 original cylinder & one repo cylinder. If this test is good, we will be selling individual cylinders.
2. We will be doing K-model threads & intake adaptions to these cylinders to see how well they handle these performance enhancements. Will post results.
VERSION 1 :Bare cylinders as cast, valve guides & thread nipple installed - 74" or 80" contact us for pricing
VERSION 2 :Same cylinders, with fitted pistons - 74" = contact us for pricing
VERSION 2 :Same cylinders, with fitted pistons - 80" = contact us for pricing
VERSION 3 :Same cylinders, with fitted pistons, ROWE Black nitrate valves & valve job - 74" = contact us for pricing
VERSION 3 :Same cylinders, with fitted pistons, ROWE Black nitrate valves & valve job - 80" = contact us for pricing
VERSION 4 :Same cylinders, with fitted pistons, ROWE Black nitrate valves & valve job, ported & flowed - 74" = contact us for pricing
VERSION 4 :Same cylinders, with fitted pistons, ROWE Black nitrate valves & valve job, ported & flowed - 80" = contact us for pricing
Note versions 1 - 3 have no flashings or port cleaning work done, and are sold as cast & cast machined.
Paul
http://www.americancyclefab.com
ACF Flathead Cylinders 008.jpg (166.8 KiB) Viewed 2515 times
ACF Flathead Cylinders 005.jpg (160.73 KiB) Viewed 2515 times
ACF Flathead Cylinders 004.jpg (165.14 KiB) Viewed 2510 times
George Greer
Post Fri Oct 29, 2010 10:42 pm
Re: Repro 13 FIN Cylinders 74" & 80"
Ya know pa's gonna edit this for you
Post Sat Oct 30, 2010 5:52 am
George Greer wrote:Ya know pa's gonna edit this for you
Indeed I did. Forum policy forbids exact vendor pricing quotes. Pa
Paul Friebus
Post Sat Oct 30, 2010 7:55 am
My sincere apologies. Paul.
Post Sat Oct 30, 2010 5:06 pm
That's not necessary Paul. We have all done it at least once, before we realized it. Most of us link to our pricing. That works pretty well. You can even state that is what the link goes to. It's good to know what is available out there in the parts world. Pa
Post Thu Nov 18, 2010 4:00 am
