Re: Flathead.......power?
On Wed, 12 May 2010 09:12:54 +0100,
<jibspirit@hotmail.com> wrote:
> hi, my names jib im from england ,and am a member of the flathead power
> tech forum, your website was recently posted as a link ,in one of the
> discussions . are your flathead oil pumps availiable please and if so
how
> much are they please, also do you have any specifications, such as flow
> rates, hot/cold oil ,etc. i look forward to your reply,thank you regards
> jib
and they replied as follows, hope this helps regards jib
Hello jib,
thanks for your interest, here is some info about the feed pump.
New oil feed pump features evolution sportster gerotor gears, aluminium
body.
It is bolt-on for harley WL, UL, G flatheads.
flows 1 liter in 45 seconds free flow.
Oil pressure is set to 25-30 psi , when operating temp idle pressure is
about 10 psi, depending on oil hole size and timing in pinion
shaft.
So, this will handle skirt oilers if you use them.
HD flatheads really need more oil to cylinders and pistons.
I recomended modern 3-piece oil rings with this pump.
in comparison,
The OEM scavender pump flows 1 liter in 30 seconds.
Ofcourse, this is not a cheap product.
price was supplied, removed to comply with boards no price policy.
Best regards,
Vesku
VT-Cycle
Pettistentie 280
21420 LIETO
FINLAND
http://www.vt-cycle.fi
+358(0)400175742
